1 members (1955 1 Series),
64
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 24 Junior Member | | Junior Member Joined: Jul 2007 Posts: 24 | swapped out the OEM radiator when i transplanted a 350 into my '50 AD. since i added the aftermarket radiator many years ago, i can't even recall the brand name, the engine runs just about right temperature wise, but extended periods of idling cause the guage to creep up.
i thought that by adding a shroud to the radiator, i could trap more air coming from the high performance fan? anybody solved this problem with a aftermarket shroud or a homemade solution?
i guess i could add a pusher fan of some sort, but i'd like to explore the simpler (and less $$$) solution first.
i so wish stovebolt.com was around when i stated this project a long time ago! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the fan is further than about 3/4" from the rad, you should have a shroud - might find one from the vendors, or just check wrecking yards for 60's 70's GM cars, many of which had'em - I found 1 and adapted it easily to my 58
Bill | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Does your 350 fan 'cut' the radiator lower than it should? Most do. The experts say the fan should 'cut' the upper/middle section of the radiator. You might be looking at an electric fan with shroud. I'd try what Red58 said first and you might get lucky.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The aftermarket fiberglass ones are junk. I bought one & returned it. The best way is to find a salvage but the older ones are rare & guys want a fortune for one. Red has a good idea about a later one but I,ve never tried that. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2007 Posts: 24 Junior Member | | Junior Member Joined: Jul 2007 Posts: 24 | okay... here's the plan a. go home and measure fan to rad distance... i'm betting it is much larger than 3/4 of an inch b. determine the "cut" which again, i think is lower than it should be c. measure for a donor shroud and proceed to junk yard d. based on results, thumb through Jegs & Summit to see how much an electric fan would cost me Jim... thanks for the make the shroud link... even tho i've done everything on this truck from sandblasting to bending brake lines, making a shroud might be low on the list of solutions... darn, now you got me thinking i could do it  | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | An electric pusher fan might be cheaper than you think. Try E-bay or pull one from a junk yard... Maybe getting your fan blades closer to the fan would help, or if you have lots of space a fan clutch might make sense. Another option might be to try 'wetter water' in the coolant. Its an additive that helps cool the engine and really works. Speedway carries a blow molded hi-temp plastic fan shroud for all different dimension radiators,including the stock size 47-59 radiator which they claim can drop engine temps by 30 degrees. The shroud for the 47-59 Chevy radiator runs about $78 + Shipping and comes un-cut so you can put the hole exactly where it should be based on where your fan blades are in relation to the radiator. The part number is 820-70. Here's some pictures: Shroud Shroud2 | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Have to admit I really don't like pusher fans. To me it always seem like you are in fact impeding airflow by putting something in front of the radiator.
Even if your fan is more than 3/4" away from the radiator, it should still be relatively simple with some thin aluminum from one of the home improvement stores to make your own shroud and assemble it with a poprivet gun. All you're trying to do is direct the airflow towards the fan.
Or you could visit an a/c shop that makes ductwork and ask them to fab something up for you. | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | I am running a aftermarket aluminum radiator with a pusher fan I picked up at the local salvage yard for #10. Running a 190 deg. thermostat, and a 17lb cap, with no shroud Have expierenced no overheating on the hottest days. Temp might rise to 200deg for a short period. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | If your fan is not as close to the back of the radiator as you wish it can be cured. They make a fan spacer in different lengths that you put between the fan and pully. Where the fan sits in relationship to a shroud is as important as the fans distance to the radiator without a shroud. The spacers arn't expensive. You might put one on to space the fan correctly without the shroud to test if a shroud in even needed.
| | | | | Joined: Jul 2007 Posts: 24 Junior Member | | Junior Member Joined: Jul 2007 Posts: 24 | thanks for all the replies... right now i have a spacer on the fan as long as they make them and thefan is still too far from the rad... it's even a high performance fan... so i'm going to take a look at the shroud mentioned by NM51... thanks by the way for the speedway kink...
NM51... how did you know the 820-70 fits the AD rads? i didn't see a fitment chart...
thanks! | | | | | Joined: Aug 2001 Posts: 154 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2001 Posts: 154 | I stayed with the stock AD radiator and 350 with a belt driven fan. I didn't want another maintenance item. I used an empty pizza box to make a pattern, had to relocate my radiator mounts to get enough room, in hind site I should have put the motor back a little farther. See it http://community.webshots.com/user/zeker6 look under Zekes'AD, Zeke
The Amish Connection 51 Chevy 1/2 ton 5 window,Vortec hotrod, no horse
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I bought one of the aftermarket ones.And yeah its fiberglas,and it works just fine.I had to trim it a little bit for a giood fit. | | |
