3 members (klhansen, 37 GC, 1 invisible), 73 guests, and 2 robots.
Topics128,112
Posts1,056,577
Members48,448
#1388604 12/16/2020 1:50 PM
Has anyone put in a larger gas tank in a 1947 to 54 suburban? If so, which one and and pics?
Mark
Is your suburban stock or modified?
In my 51 panel truck,
I put a 20 gallon tank (71-73 Mustang) out back between the frame rails.
Yes, you’ll need to move the filler tube to your desired location, but the tank fits perfectly.
You can easily fab up straps to hold the tank.
We added a second tank on the drivers side with a fuel transfer pump. 52 Suburban has a Lincoln IRS and an open driveshaft so pics probably not much help.
Evan
What did you do for the Ford sending unit not matching up with the Chevy fuel gauge
This is no longer fun
Mark
No, I have not changed the 16 gallon tank to a 20 gallon tank.
16 gallons works out fine, even on long trips.
Yes, I know that I could drive 50-60 miles further between gas stations.
I put a Gen 1 Camaro tank behind the rear axle of my panel truck. Fits like a glove, 18 gallons, tapered so it's absolutely invisible from the rear. For simplicity, security, and to avoid cutting any holes in the body, I put the filler neck underneath the wood floor.
1951 Chevy Panel Truck
