Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (GrandpasJimmy, 78buckshot), 171 guests, and 1 robot.
Topics128,290
Posts1,058,566
Members48,492
Hi all! I'm getting ready to plumb my remote filter. I can use 8an or 10an. Is the restriction difference enough to worry about? I have the fittings for 8an tubing, but am wondering if I should get new fittings and use 10an. Thoughts?
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
H Online: Content
AN fittings are measured in 1/16" increments, so a #8 line is the equivalent of 1/2". That should be plenty of volume to support a full flow system. All a #10 line will do is contain a few ounces more oil, with no real advantage at the pressure and flow rate of the 261 oil system. Be sure the dowel pin in the flow control system is in the "in" position, as that's the only way a 261 will function as a full flow oil circuit.
Can someone show a picture of where that dowel pin is 0n a 261 engine. I forget.
1951 Chevy 3100 5-window
261 cu in, 348 Head, Split Fenton Exhaust
Offy with Dual Weber 2 Bbl Carbs
'51Bowtie, to your question, here is a 261 block, driver's side view, showing the dowel pin pushed in for full flow filtering (green arrow). In this configuration, the two NPT threaded ports (blue arrows) must be connected either through a full flow filter or at least with a length of pipe or hose, 1/2" ID, in order for oil to reach the oil galleries and bearings.
Doug
1947 2nd-Series GMC FC152 3/4-ton
Follow the story in the DITY
1953 Chevy Bel Air Sport Coupe Powerglide
Thanks Jerry! 8an it is!
My Webshot Photos]
[quote=drdoug]'51Bowtie, to your question, here is a 261 block, driver's side view, showing the dowel pin pushed in for full flow filtering (green arrow). In this configuration, the two NPT threaded ports (blue arrows) must be connected either through a full flow filter or at least with a length of pipe or hose, 1/2" ID, in order for oil to reach the oil galleries and bearings.
Yep, now I remember. Thanks Doug.
