1 members (klhansen), 149 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Apprentice
Apprentice
Folks, I've been driving my '51 half-ton for several years after putting a Nova subframe in the truck and I have loved every minute. Right now I have the front of the truck apart and the Olds V-8 and Turbo 400 pulled out so that I can clean up and detail things.
When we put the new engine/trans in years ago after the subframe was already in, we left the original crossmember that supported the rear of the old 6 cylinder engine--for strength we guessed. We had to modify the crossmember for trans pan clearance and shifter linkage clearance, but basically, it's not doing anything. The frame is plated really strong at the subframe graft so the big, heavy Nova front crossmember is doing its job and the T-400 is mounted on the heavy crossmember at the rear where the original tranny mounted.
My question is: do I really need the old, rear engine mount crossmember that is really doing nothing but going from frame rail to frame rail?
I appreciate your opinions... Thanks in advance!
Rockettruck
51 1/2 ton-455 rocket!
49 1/2 ton panel-rocket-to-be!
Does that crossmember keep your frame from twisting and flexing?
Another quality post.
Real Trucks Rattle
Apprentice
Apprentice
I guess I don't know. It probably helped control flex to some extent originally, but the larger Nova crossmember along with the boxed frame at the graft probably solves that problem...
Pull it, mines gone with no issues.
1950 Chevy p\u 3100. lt1 Corvette powered.
Owner\ autoglass unlimited/Ultra Clear Body Shield
Cowboys creo: taste your words before you spit them out
http://s202.photobucket.com/albums/aa180/getm24_2000/
Mine is gone also.
Mine is gone with NP's
1952 Chevy Shortbed
Photos in Photobucket
Apprentice
Apprentice
Thanks for your input folks. I can now happily say that mine's gone as well. I learned a lot about rivet removal after a late night in the garage! I now have a lot more room for linkage and exhaust and it sure cleans up everything too!
Rockettruck
Mine is also "gone", but I was able to modify the big heavy transmission crossmember to my 700R4, so I'm not worried about flex'n the frame.
Real Trucks Rattle
