6 members (Oldpickupman, 55shaker, jay d, klhansen, TUTS 59, Quindel54), 132 guests, and 2 robots.
Topics128,195
Posts1,057,377
Members48,469
I've been looking for a replacement clutch and bearing for the truck while the engine is out and so far have only found ones that are compatible with one ton trucks. Will I have to have the one I have rebuilt or is there a place that sells the correct replacement part? The disc measures 10.75" in diameter.
Thanks for any help!
1950 3600
1951 4400
Gazz
3B Offline
Hy Gazz, Jim Carter lists their part number MEE257 which is a new disc for a 10 3/4" for a nine retaining bolt pressure plate. They also list their part number ME407 which is a rebuilt pressure plate 10 3/4" for a nine retaining bolt flywheel, there is a core charge on this part so if you don't send them your core there will be an additional charge. I will not quote prices as my catalogue is an old one, hope that helps.
Great! Thanks for that prompt and useful reply !
1950 3600
1951 4400
Gazz
Clutches Unlimited will build you a true heavy duty clutch without a core charge. I paid $155 +$27 shipping. Their number is 714-373-6155 website is clutches unlimited.com. their clutches are better than anything you're going to get out of a catalog
