7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 251 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 251 | I've been looking for a replacement clutch and bearing for the truck while the engine is out and so far have only found ones that are compatible with one ton trucks. Will I have to have the one I have rebuilt or is there a place that sells the correct replacement part? The disc measures 10.75" in diameter. Thanks for any help!
1950 3600 1951 4400 Gazz
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Gazz, Jim Carter lists their part number MEE257 which is a new disc for a 10 3/4" for a nine retaining bolt pressure plate. They also list their part number ME407 which is a rebuilt pressure plate 10 3/4" for a nine retaining bolt flywheel, there is a core charge on this part so if you don't send them your core there will be an additional charge. I will not quote prices as my catalogue is an old one, hope that helps. | | | | | Joined: Mar 2006 Posts: 251 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 251 | Great! Thanks for that prompt and useful reply !
| | | | | Joined: Sep 2019 Posts: 204 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 204 | Clutches Unlimited will build you a true heavy duty clutch without a core charge. I paid $155 +$27 shipping. Their number is 714-373-6155 website is clutches unlimited.com. their clutches are better than anything you're going to get out of a catalog | | |
