2 members (FAST55, Hanks custodian), 130 guests, and 3 robots.
Topics128,038
Posts1,055,584
#1387826 12/11/2020 12:25 AM
Former BMW Rider
Former BMW Rider
As much as I hated to, the '47 was taken for its last run of the season this afternoon. Snow is in the forecast for this weekend. I had just visited a local car dealership and was telling the gang there about adding some fuel stabilizer and topping off the gas tank. A couple of these guys said they quit using fuel stabilizer and now opt for 'no alcohol' premium gasoline. I don't think there's even $0.20 difference between the 87 and 91 octane gasoline in eastern Iowa. These guys are convinced it's no problem and are using it in their small engines and classics too! FWIW, I used the last of my gas stabilizer and topped off with no alcohol premium...........
Any opinions or experiences, good or bad?
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
I have switched to non/no-ethanol gasoline, if I can find it on a trip.
I can pretty easily get it near me in North Eastern NC (boat engines need it - maybe farm tractors need it?).
I also use it in my gas-run garden equipment.
I learned this after Home Depot and Toro lied to me about their "no ethanol" gas "policy" (until I showed them their "warranties").
AD Addict & Tinkerer
The gas stabilizer also keeps the gas from going stale.
For years before I retired, I lived in a county that did not sell non-ethanol gas. I treated every gallon of gas with Sta-bil I put into my tractor, lawn mower, weed wacker, snowblower, rototiller, leaf blower, snowmobiles, and 4-wheeler. I had to clean out 5-6 carbs a year due the the alcohol gelling. Since I retired, I moved to a county that sells non-ethanol gas. I still treat every gallon of gas I buy but carb cleaning is at a minimum.
Phil
Project Journals
Stovebolt Gallery Forum
Moderator
Moderator
2 Offline
Yup! Non ethanol fuel is all I buy the last ten + years.
Separate hose at the Casey’s station so I know I am getting the real thing and not the leftover that may be in the hose.
Year old gas is still good for firing up a 50 year old engine.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
It's not either/or - it's BOTH. Fuel stabilizer and ethanol-free gas do two different things.
Ethanol is hydrophilic - it attracts water from the atmosphere. Vehicles that aren't driven daily need ethanol-free fuel.
Stabilizer keeps gas from going bad, ie losing its octane and turning to varnish. You need it if your gas isn't used up every few months.
I was in the wholesale petroleum business for 40 years.
1951 Chevy Panel Truck
I've always used a stabilizer in my tractors, mowers and trucks. This past year we got a new Casey's station in town which has the ethanol free premium. So now I'm using both. The premium gas is quite a bit higher, but if it wards off these other problems I feel it will be worth it.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
ALL of the above are correct. The only thing I will add is that one of my 54-3100's which is a daily driver I add 1oz. per ten gallons of chain saw oil. This cushions the valves like the lead used to do. 70.000 + miles and runs great. No carb problems. If I have to let my project 235 set I add Sta-bil. I believe it was justhorsenround that shared a link regarding a comparison of additives (which were the best and which are the best to NOT use), a month or so ago. I unfortunately live in Central Florida so ethanol is hydrophilic 24/7, 365. Doc.
I am extremely averse to burning ethanol in any engine I own - especially in the older machines. The old engines like lead - not water.
For about a decade I flew single engine piston driven aircraft cross country , tracking migratory birds. Avgas contains no ethanol.
If an automobile or truck engine fails , you ease over to the side of the road , get out , cuss a few times and pull out the cell phone.
If an aircraft engine fails , the event is a bit more interesting. Especially single engine ... over the Appalachians.
Corn is for food and liquor.
Yes I am with PHAK1
We live in an area where there is a local gasoline station "Stewarts" that sells non-ethanol gas...it is like .70 cents more a gallon, but come spring...vroom vroom vroom....and we are off and running...all of my air-cooled garden type stuff is the same...the gasoline doesn't even smell like the current day gas...
I feel bad for you guys that don't have it...it works awesome...
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
Former Workshop Owner
Very good topic. thumbs_up I only use non-ethanol gas in all of my gas powered lawn/outdoor equipment whether it's new or old. It's only in the fall that I mix 5 or 10 gallons with Stabil and run it through all of my equipment before winter storage. I do the same exact procedure with my '59 Viking (292 straight six). It doesn't leave my property anymore as it is no longer licensed or insured. The Viking is only utilized 2 or 3 times a year around my place while trimming trees. Just last week, I charged the battery, started it up and added 3 or 4 gallons of fresh non-ethanol gas with Stabil. I let it run for 30 or 40 minutes before retiring it for it's winter slumber.
This routine has been working well for me for the past 15 years.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I mix Sta-bil with my gas every time I fill the cans. The reason being is sometimes the equipment gets put away sooner than I think and this way, I don’t have to worry if I added Sta-bil, as it’s all been treated. Sta-bil is less than $10 to treat 80 gallons and I don’t go thru that much in a year. The only exception is my boat and jet ski. They use too much gas (always non-ethanol) and get treated at the end of the season.
Phil
Project Journals
Ethanol has ruined many a fuel tank & worse, not enough time now to get started on my rant!
BC
1960 C60 pasture art
Former BMW Rider
Former BMW Rider
Thank you all for your responses, I definitely learned a few things as a result of this thread. I can always count on Stovebolters to come through! thumbs_up
Andy
For those of us that don't have ethanol-free gas nearby... has anyone looked into running something like "TruFuel" through their carb/lines before shutting up for the winter. Supposedly its an ethanol free 92 octane gas - however runs about $20/gallon from places like menards/home depot/ lowes. Not a feasible option for filling the gas tank.
I have used this at the end of the season for the last few mows (push mower) and leave it in the tank all winter - usually starts up in 1-2 pulls, but never used it in anything else due to the cost.
Crusing in the Passing Lane
Aircraft fuel has no alcohol, 80 octane is best but they might only have 100ll. Got to a small airport where they have no jets.
Ed
Insomniac
Insomniac
Did you check this website to find ethanol free gas?
https://www.pure-gas.org/index.jsp?stateprov=OH
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
Sta-Bil also make an additive for Ethanol fuels, I have used it in my mowers and chain saw with good results.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Insomniac
Insomniac
Sta-Bil makes 2 gasoline additives which can lead to some confusion. The "storage" product gives longer protection than the "360" product. Both products are good for ethanol. I only use the "storage" product.
https://www.goldeagle.com/shop/brands/sta-bil/?fwp_applications=fuel-treatment
Gord 🇨🇦
I don’t have any of the ethanol problems people talk about. I don’t use any stabilizers, or additives. My stihl weed eater gets out away for 6 months and I have no problem starting when I get it back out and it’s 9 years old. My generators sits for the same amount of time and no problems there either. My 51 (with a 59 235) is fuel injected now and does well with ethanol fuel. My Mercury boat motor is the only thing I own that doesn’t like ethanol fuel.
Sludgeburner, I hope you have some wood to knock on, as you just jinxed yourself and ended you lucky streak! LOL
In case you didn’t know, most 2-cycle oil you mix in with your gas for chainsaws, weed wackers, etc, contains a stabilizer for gas.
Phil
Project Journals
