3 members (Otto Skorzeny, Youngin' Tut 59, delky), 114 guests, and 4 robots.
Topics128,186
Posts1,057,302
Members48,467
I've got a 1938 Chevrolet 1/2 ton pickup with a S10 rear end, leaf springs and shocks. I do have wider than stock rear wheels/tires. Runs great on level ground, but when turning either direction over uneven ground, the rear tires rub on the pickup bed sides. There's about a finger width's clearance between the tires and bed sides while sitting level. If I jack up one side (or the other) of the rear end the tire tilt's in and touches the bed side. Would installing a rear sway bar help the situation?
Adding a sway bar will stiffen the ride.
Changing the wheels to a different offset will give better clearance.
Unfortunately, the rear fenders won't allow me to move the rear wheels/tires out for additional clearance.
What size tires are you running? Not a '38, but I've run 255 15s on my '40. They would just touch the bedside with a load and bumping one side up like when pulling into my driveway. I've since gone down a bit to 245's and no rubbing.
Dennis
40 Chevy 1/2 ton
Running 235/50R17's,
H Online: Content
What's thre reason for the wide tires? Even a little standing water in a rainstorm will have the rear end of a vehicle that lightweight hydroplaning like Miss Budweiser at any normal highway speed.
Fiberglass rear fenders, 2" wider then stock, problem solved!
That’s a great looking truck!
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Steveo325 , I have 245/75.16 on the rear of my '40, there is a good 2 fingers width clearance inside the tyre, and, although it is close to the guard , there is never any rubbing, I'm not sure what the issue is , oh, wait , the '38 has a narrower deck ?? pulls the guards in , not enough room for the wides? (I built my deck 4ft wide) pic attached.
After some additional measuring, I believe wheels with less offset (as Dusty suggested) will fit.
a panard bar controls side to side motion (i.e.: body side force on the springs) the longer the better, a sway bar controls body roll.
btw: that IS one great looking 37
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
Crusing in the Passing Lane
4wd S-10’s rear axle is 2” wider than 2wd, do you know which you have?
Ed
