7 members (kades51, DennisM, Jon G, baldeagle, JW51, 68ironhead, Stovebolt48),
53
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 394 'Bolter | | 'Bolter Joined: Nov 2002 Posts: 394 | How much D.C. voltage should I be reading at my headlamp terminal in my light switch and the Battery terminal of the dimmer switch? | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | Should be VERY close to what you measure at the battery.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Whatever voltage the battery or the charging system is producing, less maybe a couple of tenths of a volt for losses associated with connections. There should be little or no voltage loss in the wires between connections. Dimmer switches carry a pretty heavy current, and they live in a very hostile environment where rain, dirt, and road splash is present. Contact failures inside the switch are pretty common. Jerry
