| | | Forums66 Topics128,109 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | Hi fellas, looking for some help with identifying a stovebolt in one of my trucks. I have downloaded several GM casting number lists but can’t find this one. Cast # 839253 Serial # TR4045370 Any help much appreciated, Dave | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Is the the Canadian Military Pattern (CMP) truck that you have posted about before?
If not, what do you know about the engine?
Canadian or USA? Chevrolet or GMC? domestic or military?
Presumably, it is a Stovebolt - is it a high pressure or low pressure engine? Does it have a 15 bolt head or an 18 bolt head? | | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | This is in an MCP (modified conventional) therefore should be military. Canadian built 1542 Stake Side right hand drive. I don’t know if the engine is original to the truck. I haven’t had the rocker top off so am unsure of head bolts. Is it not possible to identify solely from the cast and serial numbers? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | Many thanks, I haven’t seen this info before. I’ll check it out. | | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | Been busy with other things the last few months but back trying to positively identify this engine, hoping to ascertain size and year. I can’t find the cast number listed anywhere - 839253.
I’m fairly sure the serial number starting TR makes it Canadian built, destined for a right hand drive vehicle and the following digits starting with 4 places it as 44 built - anyone able to confirm this?
A few external observations: Rocker cover secured with 2 nuts on top Side cover extends over spark plugs Carter W1 589S carb (I know 216 runs carter, does 235 also or Rochester?) Low pressure engine (no external oil filter)
My thoughts so far are 216 or pre 54 235, can anyone suggest other things to investigate without tearing into it too much?
Many thanks, Dave | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | It's in the link Tim posted above. Search for TR4 finds: [T][TR][C][CR] 4020000-4085000? [216] R means right hand drive.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jan 2017 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 14 | It's in the link Tim posted above. Search for TR4 finds: [T][TR][C][CR] 4020000-4085000? [216] R means right hand drive. Forgive me but I still can’t see it on there, maybe because I’m using a phone. I’ll try and take a look on a computer this week. Many thanks. | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Computer is probably better. I don't know how to use <ctrl> F on a phone!
