7 members (Rusty Rod, TUTS 59, 55shaker, RLB, WICruiser, Gdads51, Jay R),
102
Mod | | | Forums66 Topics128,054 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | Looking for some advice. I was prepping to weld in a patch panel and noticed where I sanded through on a edge there was what looked like a reddish brown layer under the epoxy primer. There is also an area that appears to be showing rust coming through on the door pillar. I had my cab sand blasted and epoxy primed a couple of years ago and the person that did it had it back to me in a week. I don't know how long between blasting and priming. I realize it will need re-priming but am I going to have to strip the cab again? Thoughts?
Thank you!
1950 Chevrolet 1/2-Ton 3100
| | | | | Joined: Jul 2000 Posts: 2,191 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,191 | You might have pin holes in the metal where moisture can get in from the back side.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Looking for some advice. I was prepping to weld in a patch panel and noticed where I sanded through on a edge there was what looked like a reddish brown layer under the epoxy primer. There is also an area that appears to be showing rust coming through on the door pillar. I had my cab sand blasted and epoxy primed a couple of years ago and the person that did it had it back to me in a week. I don't know how long between blasting and priming. I realize it will need re-priming but am I going to have to strip the cab again? Thoughts?
Thank you! What was used for the blasting media?
| | | | | Joined: Jan 2019 Posts: 21 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2019 Posts: 21 | I'd ask him what he used. It's hard to tell without photos, but he may have etched it prior to priming. If it's rusting under the primer, inevitably you'll need to strip it.
1949 GMC 100 1/2 ton 1969 Stingray convertible 2011 RS/SS Pace car
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | An actual good epoxy primer should not do that. It seals. Something fishy here. BE SURE it is rust. BE SURE it was a brand name two part epoxy primer on bare metal. Any good sandblaster knows it needs primed pretty quick. Except where I live  As Robert is asking: Some people refer to all blasting as "sandblasting". Find out what was used: sand, glass, black magic, garnet, soda, walnut................etc. If it was a redish brown "layer", it is some sort of primer.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | I've seen a few other instances where someone sanded through their epoxy primer coat while blocking and found rust UNDER the epoxy where it had been previously blasted clean. In all cases the media that had been used was sand. Most sands contain caustic salts that, when used for a blasting media, are being pounded into your sheet metal. It may be about the cheapest media out there, but it is not ideal.. I think you'll find the instant money savings results in more effort to clean that salt residue. I prefer an inert media, such as Garnet or Coal slag. They have less chance of these adverse effects, and are well worth the extra money. Especially now that the paint substrate adhesion is questionable.. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | | | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | Im not certain what was used I would assume sand but that would be a guess. In regards to the primer it is a 2K epoxy primer from SPI. I have done some spot checking in various other areas of the cab and have not noted rust under the primer. I might go back to the location and see what the extent is. That being said if I moved on in the build I would always be nervous that rust would rear its ugly head eventually. I new I should have kept it with the old patine and let well enough alone.
Thanks, Eric
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | SPI is the best you can get if applied properly. If it was soda blasted, that is the problem.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Im not certain what was used I would assume sand but that would be a guess. In regards to the primer it is a 2K epoxy primer from SPI. I have done some spot checking in various other areas of the cab and have not noted rust under the primer. I might go back to the location and see what the extent is. That being said if I moved on in the build I would always be nervous that rust would rear its ugly head eventually. I new I should have kept it with the old patine and let well enough alone.
Thanks, Eric Eric, not to split hairs here, but is it Epoxy or is it 2K? They are not one in the same. About 3 coats of epoxy and it will seal out moisture from your sheet metal. 2K is their high build primer, which is a more porous paint, it does not seal. So if you indeed used 2K primer, it is possible that moisture crept through the primer and rusted the panel. If it is Epoxy Primer, I would lean more toward media blasting/prep being the culprit. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If a person is not an expert in automotive finishes, it is perfectly OK to call the Epoxy; 2K epoxy primer. It is sort of redundant, but not a hair splitting experience.
2K, in the vernacular, simply means 2 part. SPI epoxy primer is 2 part.
An expert will call primers; 2K primers and call epoxy primers; epoxy primer. Dongray has already said it's SPI epoxy. We know what that is.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | This isn't a bad place to be educated on such details. Might even save some embarrassment when asking for product at the paint shop. | | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | I don't know where you are in DFW, but the best people to talk to about primer, paint, etc around here are the folks at English Color & Supply. I've dealt with them for almost 50 years, and you'll have a hard time finding more honest and helpful folks.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Mar 2014 Posts: 4,482 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,482 | And by the way if you want to know if what you're seeing is rust or not, get some strong vinegar (not kitchen vinegar...you need 10% strength or better). Dip one end of a Q-Tip in it and put that on your suspected rust. If you see bubbling, it is rust. If no bubbling, suspect it is primer, paint or possibly even some sort of sealer.
| | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | MNSmith and Bartomas thank you for your input. I understand the differences in the chemical composition of the various base polymers but in regards to what the industry terminology is used or the pros and cons of them I have very little knowledge. I do appreciate the nuances and being made aware of them even if not always needed. Thanks again
JonG, I will take a look at the rust area over the weekend and perhaps try the vinegar test with a small amount as mentioned. BTW-there is an English Color right down the road from me so that is great to hear of a good reference. I have walked in there once to purchase some pro 15 and talk about being out of my element in regards to finishes. Thanks again.
