0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
I'm thinking about converting my '95 lt1 to a carb setup that I currently have in my '50 3100. I have it coupled to a 4L60E tranny. Is there a computer unit out there to run just the 4L60E tranny, i.e., much smaller, less programming?
It's actually possible to make a silk purse from a sow's ear- - - -but it makes the pig look funny and it doesn't hear very well. If you want a truck with that engine/trans combination, wouldn't it be simpler to buy one with that setup from the factory?
I believe there are few few companies that make stand alone controllers, but I don't have that info handy at the moment.
Why would you want to go away from that nice, efficient EFI system? That's the whole reason for dropping a late model in there!
Sir Searchalot
Sir Searchalot
This would be a huge headache. Lots of parts need changing. Forget the idea or swap in a carb'ed 350 with a 700r4, Sell the other set. Should be a relatively easy swap. You may come out about even, money wise.
Haha, my most recent experience with those "efficient" EFI motors:
1951 Chevy Panel Truck
Diesels are a whole nuther topic!
Just answered this question for another poster, is your block bored for fuel pump push rod, does your cam have the lobe for the
fuel pump, is your motor a roller motor, if so cam lobe seperation is different between carb and EFI, idle issues. I am building mine
as we speak.
You Learn more Listening than Talking
