2 members (Hawkman, 52GMC35424JD), 97 guests, and 1 robot.
Topics128,051
Posts1,055,768
#138556 06/30/2007 11:06 PM
OK I have a 51 3100 and I am planning on lowering the rear with lowering blocks...
I would like to go 3 inches in the rear...
I still have my torque tube...
will I get away with this without effecting the driveline adversely?
Or should I go with a 2 inch drop?
"I'd rather have a bottle in front of me than a frontal lobotomy."
-D. Parker
1951 Chevy 3100
#138557 07/01/2007 1:35 AM
Think you'll have some problems with the closed diff as the perches pivot on the springs. You might be able to pop out a couple spring leafs.
You might do a "search" and find more specific info.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#138558 07/01/2007 1:41 AM
I think it'll work. In my reckless youth I lowered the back of my '49 Chev fastback 6" by stacking 2" blocks on top of 4" blocks using extra long U-bolts. It also had a torque tube, no problems. The car still had a mean rake with homemade dropped spindles and 2 coils cut in the front end. Needless to say, there were a lot of driveways and service stations I had to avoid.
#138559 07/01/2007 1:58 AM
my front has a 6 inch drop on it... the back is now TOO tall...
I just want a 3 inch drop to give it a mean rake...
I wanted to put the blocks between the perches and the leaf springs
-D. Parker
1951 Chevy 3100
#138560 07/02/2007 5:36 AM
mike ,
Just a suggestion ...if ya go that route after you are satisfied with the stance ...I would weld the blocks in Not to the springs but the perches ...dont rely on the U-Bolts to hold em in ..ive seen blocks shoot out under a hard load in the past ..
1952 Chevy Shortbed
Photos in Photobucket
#138561 07/02/2007 2:26 PM
smart idea
-D. Parker
1951 Chevy 3100
#138562 07/02/2007 5:18 PM
Just be careful your u-bolts don't stick out below your rim. If you ever have the misfortune of having a flat while driving you don't want that u-bolt catching the ground first.
