1 members (WICruiser),
164
0
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | good morning to all my son and i are doing some motor work to the 216 on the 37 canopy. we fired it up after several attempts not knowing that someone had messed with the distributor. well it fired up, we removed the valve cover and noticed one valve is not moving. the spring will manually move but not the piston. any ideas? thank you all in advanced | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Piston or valve not moving? If it’s the valve, spray with a good lube and using a 2X4 block and a hammer and tap on the valve to see if you can free it up. Best to remove the rocker assembly if you can’t get to the valve stem to tap on it. If it’s the piston get your wallet out it’s gonna be a wild ride. Good luck.
| | | | | Joined: Jan 2011 Posts: 237 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 237 | | | |
