5 members (78buckshot, dt235sd, Southerntruck, CandoBrent, 2-Ton), 107 guests, and 3 robots.
Topics128,128
Posts1,056,661
Members48,450
#1384935 11/17/2020 1:38 PM
Alright folks, my question of the day is. Is the width of the boxes on the 1940 Chevrolet trucks the same as the 1950's Chevrolet trucks??
My 53 chevy is 50-1/2 inches wide. The reason i'm asking is I found a Barden bumper on here. It originally came off a 1940 Chevy truck. The box looks the same. I know the rear fenders are different a bit. I have a welder and all the tools to make it fit. At least I would have a great start in having a Barden to use.
ELMO
3B Offline
Hy Elmo, according to the Truck Data books that cover the respective years, the 1940 box is 48 1/2" wide inside, the 1950 box is 50" inside, hope that helps.
But doesn’t the Barden Bumper mount under the box! Not around it??
Anyone know how the Barden Bumper mounts!
Elmo
From my saved pics
The bed widths are different as 3B noted. But the width between fenders where the bumper bolts to the fenders would be a bit more critical. But it wouldn't be that hard to modify one from an earlier to fit on an AD.
Isnt your truck a 3/4 ton?
Is the bumper off a 3/4 ton?
Is the frame wider on a 3/4 ton compared to 1/2 ton?
I think you will need to find out the frame widths, nothing that cannot be overcome with a grinder and welder.
This is a situation that I'm sure we can all agree. The Barden looks wonderful. I can reflect on many of the Folks here in Central FL they made everything look good when it came to their Chevy's. There were so many of them here because there was not a Ford dealer locally until 1957. It took more than several years for Kissimmee to trust Ford. Doc.
[quote=DADS50]Isnt your truck a 3/4 ton?
Thanks DADS50 for that picture and question.
You make a good point.
Elmo
My frame width is 3 foot wide. Not that it makes any difference at this point.
Elmo #1385028 11/18/2020 12:41 AM
Thanks DADS50!!!!!!
For all the pictures. I have a better understanding on how the Barden Bumper is is Fabricated. It looks pretty simple. I'm going to order up some 3/16 Diamond plate and some flat stock steel to fabricate my own bumper.
And I'm going to call the Elmo Bumper!! LOL
Elmo
Elmo #1385030 11/18/2020 12:51 AM
Sounds good
I can get you a few more detailed pictures tomorrow, sound like the 3/4 ton frame is not as wide the 1/2 ton?
Custom built sounds like the way to go
Make sure you add a custom label
Im putting one back on my truck some day. My dad had one on there back in the day
Warning! Ethnic slurs along with any inappropriate postings will be deleted. Continued attempts will result in a Stovebolt time out.
Looks like the 3/4 ton is 10 inches narrower at the rear frame compared to 1/2 ton
DADS50
I wonder why the 1/2 ton would have a wider frame than a 3/4 ton? Huh!
Elmo #1385121 11/19/2020 12:28 AM
Not sure
But if your donor is 3/4 ton you might be ok
[quote=DADS50]Sounds good
Do you have those detailed pictures of the Barden? That would be cool to have in my files
P.m. me your email address
Kinda hard to capture in photo and there is an attachment limit
I have more i can email
Elmo #1385210 11/19/2020 10:04 PM
Holy over load on the pictures for the construction of the Barden Bumper!!
And that video is fantastic.
Now I have a complete understanding on how it goes together.
Thanks DADS50
People like you is what makes this forum so great!!
Elmo
Elmo #1385219 11/19/2020 11:14 PM
thumbs_up
Good luck on your build
Elmo #1385278 11/20/2020 12:56 PM
Crusty Old Sarge
Crusty Old Sarge
Seems I remember the Dealerships would weld their name on the bumper as well. When I lived in OKC as a kid almost every truck had a Barden style bumper, you could tell where it was from by the name welded on it.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Originally Posted by Elmo
DADS50
Stronger. Ever noticed how the rear section of any big trucks (tractor, 10 wheeler, tri axle dump ect..) have thick rails that are usually fairly close together? That’s because they can be made to have less flex and carry a higher load weight than a thinner frame spaced out farther. Also makes room for inboard wheels in dually application
