| | | Forums66 Topics128,129 Posts1,056,361 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13842 05/31/2003 4:12 AM | Joined: Mar 2003 Posts: 93 'Bolter | | 'Bolter Joined: Mar 2003 Posts: 93 | From bitter personal exerience, I would recommend that any one considering changing the torque tube bushings on a 47 1/2T re-think the project. Just leave the old ones in there 'cause the new ones will be too tight and won't line up with the drive shaft. Five hundred bucks worth of machine shop work and the torque tube is just a boat anchor. Can a '55 or later drive train be used to eliminate the torque tube and differential? Does any one want to buy a '47 with nothing connecting the transmission to the wheels? | | |
#13843 05/31/2003 5:46 AM | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | 47 Chev,
Welcome aboard the Stovebolt page.
Got any more details about what's gone amuck on your driveshaft fix?
Plenty of folks with ideas, knowledge and even sympathy here at TSBP. (ask Chiphead!)
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
#13844 05/31/2003 6:51 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Welcome to the 'bolt 47Chev , ,I'm sorry you have had a bad experience with your repairs . I have done some of these , and all the okie bushings have come from Jim Carters ,, is this where you got yours from ? One I did , the bushing was 0.008" to large in dia to go in the torque tube and I had to machine it down to the correct size ,, But I have just done one on a '37 that was perfect in every respect . I think that perhaps the quality control could be improved there . On the other part of your post ,, the installation of a later diff is not too difficult , mostly making the decision of what to choose can be confusing . I have a '55 truck diff in my '40 pickup, it is an easy fit and has several benifits for me . If you really want to go this route I will expand further on your request .
Give us more information on your troubles and what you hope to achieve next . | | |
