3 members (MickeyP, 2-Ton, 1955 1 Series), 122 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
#1383451 11/04/2020 5:37 PM
I took the carb and manifold off of the 46 chevy Coe that I dismantled. It had a high pressure 235 in it. The carb is a Carter BB-1, would that be the original carb off of the 216 or would it be the original carb for the 235? Dave
Would the carb off of the 216 have a different bolt pattern for the manifold than if it was for a 235?
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
Any Carter Updraft, from a 1946, or later COE, would have a 235 engine in it. No 2 ton Chevrolet trucks, ever had a 216 in them. Chevrolet's first 2 ton rated trucks appeared in 1946.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
But Spanky this is a high pressure 235.
1941 Chevy
It's got to be a later 235 which were in cars and trucks, I had to file the original manifolds on my 46 COE to get it to bolt on a 1960 235.
The bottom line here is this, I know this manifold came off of a high pressure 235 that was installed in a 46 Coe. I have no intention of using it, if I try to sell it I want to represent it correctly. I do not know much about it. Would the carb to manifold bolt pattern be like the ones on downdraft stovebolt that changed when they went from the 216/235 low pressure engines to the 235/261 high pressure engines. I don't have those dimensions off the top of my head. Dave
1941 Chevy
I put the manifold from 1946 235 low pressure engine on the 1960 235 high pressure motor. Had to do a little filing for clearance for the mounting bolts
There were four different Carter Updraft carb.s used on Chevrolet COE's from 41- 55.1. 1941 Carter model 489, 42-50 model 517, 51-53 model 871, and 54-551st series model 2045. 41-50 manifold carb., mount the same, 51-55 1st series carb., mount the same. The 54/55.1 Carter 2045, mounts facing forward, because the air cleaner is under the hood.
Spanky Hardy
1950 GMC 250 1-Ton
All I see on the carb I only see BB-1 and D or O. - 456. And today I compared it to a rochester that came off of a high pressure 235 and the Rochester patern is wider. Would this mean it came off of a 216 low pressure engine?
1941 Chevy
The mounting flange on the 489, and 517 is smaller than the later 871, and 2075 updrafts. So your carb., is probably a Carter 517, which would be from a early 235.
Spanky Hardy
1950 GMC 250 1-Ton
Thanks Spanky. Dave
1941 Chevy
