| | | Forums66 Topics128,130 Posts1,056,370 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | I took the carb and manifold off of the 46 chevy Coe that I dismantled. It had a high pressure 235 in it. The carb is a Carter BB-1, would that be the original carb off of the 216 or would it be the original carb for the 235? Dave
Would the carb off of the 216 have a different bolt pattern for the manifold than if it was for a 235?
1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Any Carter Updraft, from a 1946, or later COE, would have a 235 engine in it. No 2 ton Chevrolet trucks, ever had a 216 in them. Chevrolet's first 2 ton rated trucks appeared in 1946. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | But Spanky this is a high pressure 235. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | It's got to be a later 235 which were in cars and trucks, I had to file the original manifolds on my 46 COE to get it to bolt on a 1960 235. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | The bottom line here is this, I know this manifold came off of a high pressure 235 that was installed in a 46 Coe. I have no intention of using it, if I try to sell it I want to represent it correctly. I do not know much about it. Would the carb to manifold bolt pattern be like the ones on downdraft stovebolt that changed when they went from the 216/235 low pressure engines to the 235/261 high pressure engines. I don't have those dimensions off the top of my head. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | I put the manifold from 1946 235 low pressure engine on the 1960 235 high pressure motor. Had to do a little filing for clearance for the mounting bolts | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | There were four different Carter Updraft carb.s used on Chevrolet COE's from 41- 55.1. 1941 Carter model 489, 42-50 model 517, 51-53 model 871, and 54-551st series model 2045. 41-50 manifold carb., mount the same, 51-55 1st series carb., mount the same. The 54/55.1 Carter 2045, mounts facing forward, because the air cleaner is under the hood. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | All I see on the carb I only see BB-1 and D or O. - 456. And today I compared it to a rochester that came off of a high pressure 235 and the Rochester patern is wider. Would this mean it came off of a 216 low pressure engine? 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | The mounting flange on the 489, and 517 is smaller than the later 871, and 2075 updrafts. So your carb., is probably a Carter 517, which would be from a early 235. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
