| | | Forums66 Topics128,196 Posts1,057,385 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Hello all,
Does anyone possibly have the rear wheel seal part number for a 46 1.5 ton?
Thanks | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Per my 1951 Parts Book; 5.822 Axle Shaft Seal 1937-47 All Utility....rear wheel hub oil seal....3681195* * NOTE 3681195 not used w/splined type shaft and hub, use 3686530 for spline type. Mike B  | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Thanks, just to clarify is that the seal for the 1.5 ton? | | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy Lend-Lease 1.5 and guys, I looked at this from the jobber perspective, my old Victor catalogue lists their part number V49904 for the splined type, that translates to National part number 6358 which also translates back to GM part number 3686530. the Victor p/n for the non splined hub is V49799 that translates to National p/n 5850 unfortunately that does not translate back to the other GM p/n that Mike B supplied, but that number may have been superseded, hope that helps. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | One more question, Myv46 has a standard rear differential it is not a two-speed. When it says splined the only splines I recall are on the end of the axle shaft where it slides into the diff. Is the shop manual referring to something different? A different type of axle shaft? | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Thanks, just to clarify is that the seal for the 1.5 ton? The Parts Books list "COMMERCIAL" as being 1/2 thru 1 ton vehicles and "UTILITY" as being 1-1/2 and 2 ton. Mike B  | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | Again just to clarify, what is the difference in unsplined and splined hub on these big trucks? Upon checking several websites it seems they only list on part for these grease seals. | | | | | Joined: Jan 2010 Posts: 210 'Bolter | | 'Bolter Joined: Jan 2010 Posts: 210 | 3B, so after doing some research, you're correct that GM 3686530 cross's to National 6358, however so does GM 3681195 posted by Mike B. I went to Rockauto and searched both GM seals and both returned to SKF 31870. Went to National's site and used the SKF 31870 which crossed to 6358. So apparently both styles of Hubs use the same seal. I've always thought the research is half the fun working on old stuff.
Thanks | | |
