4 members (Charles in CA, Shade Baby, Hotrod Lincoln, 46 Texaco), 119 guests, and 3 robots.
Topics128,162
Posts1,056,913
Members48,458
I suspect that there is a well known method of matching a set of lose the grill bars to the correct position on the grill support frame. Identifying the top grill bar is obvious (even to me)... how about helping an old man match the rest? Many thanks, Stovebolters, for putting up with my many curiosities about what has to be one of the most beautiful vehicles from the 40s and 50s.
1952 Chevy 3100
Cant help you but here are a couple of links you can look at
https://pbase.com/dennygraham/1950_grill&page=all
https://pbase.com/czechman/grill
When I restored my '50 COE grill, I recall that the horizontal bars were stamped with a single digit, indicating which bar it was. Now this is a big bolt grill and therefore taller than yours, but constructed the same. I don't remember where on the bar the number was, other than it was hidden from the front. Look carefully and see it yours have a number.
Kent
1937 Chevy 1/2 ton
1942 Chevy 1/2 ton
1947 Diamond T Model 509
1951 Chevy 1/2 ton
The outer grille bars have notches stamped in them on the rear lip of each outer bar (1notch,2 notches,3 notches,4 notches),
This matches a corresponding notch on each inner grille bar to facilitate the match ups.
Each bar is slightly shorter in length with the longest bar at the bottom of the assembled grille, then the next longest etc....
There is a Tech Tip under Grille that illustrates this also with good advice to run an external ground wire between both lamp housings to ensure good ground continuity.
Hope this helps!
I am assuming this is a Chevy AD style truck you are working on.
May I suggest to edit your preferences that will automatically post your truck year and make in your post to help out.
Mike
1951 Chevy 1/2 ton w/ 1959 235
1971 Chevelle
What he ^ said. Here's a photo of the notches. Look near the center support.
all of you... you make my life easier. Thank you!
1952 Chevy 3100
