1 members (UtahYork), 215 guests, and 1 robot.
Topics128,101
Posts1,056,181
Members48,436
#1382833 10/30/2020 5:35 PM
Help me remember: do 1948 and older 216 and 235 have 10 mm spark plugs? I should know this. Thanks.
Professional Novice
The 1946 model 216 I just disassembled does- - - - -I'm wondering if it would be possible to drill and tap those heads for 14MM plugs? The 10MM variety are scarce, expensive, and prone to cross-threading. It should be pretty simple to set up my valve seat and guide machine with the air-float work table to do an accurate job of opening up the plug holes to the bigger threads, as long as I don't hit the water jacket in the process of enlarging the holes.
Yes: the spark plug diameter changed from 10mm to 14mm in 1949 model year.
The start/top of a "model year" is not a specified date.
I think that 10mm plugs were just a war time thing . I know the early 216 , thru to '40 have 14mm plugs .
Thanks for causing me to look this up, Dusty
1929-1932 non-metric (7/8" x 18 thread)
1932 18 mm
1933-1940 14mm
1941-1948 10 mm
1949- 14mm
Thanks Tim. Thanks all. There is so much misinformation on the internet. I’ve probably spread some of it myself. The first motor vehicle I owned was a 40 Chevy car my grandpa gave me when I was a teen. I took the engine partially apart. It had flat top pistons, 14 mm plugs and a tall side cover. I always believed it was a 216. I guess it was a 49-53.
Professional Novice
Looking at the chart 1940 was 14mm..... the 10mm started in 1941 if i am reading the chart right. (I wasn't around then so I can't tell from personal knowledge).
Personally I would stay with original plug size. I have never had problems with the 3/8ths (10 mm), plugs, granted they may cost more but I have so many AC's in stock. Doc.
Here are the AC Delco, Autolite, and Champion part numbers.
AC (Delco) was the original GM spark plug brand.
Specialty, Marine?
I guess Stovebolts are Special. grin
I think 1940 was the last year 216s had domed pistons. That’s why I think mine (all those years ago) had a 49-53 engine.
I guess a 40 block could have been fitted with flat top pistons and a later head...
Sorry guys, too much time on my hands.
Thanks for all responses.
Professional Novice
