3 members (klhansen, ronsway, 1 invisible),
165
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Help me remember: do 1948 and older 216 and 235 have 10 mm spark plugs? I should know this. Thanks.
Professional Novice
| | | | | Joined: Feb 2004 Posts: 29,801 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,801 | The 1946 model 216 I just disassembled does- - - - -I'm wondering if it would be possible to drill and tap those heads for 14MM plugs? The 10MM variety are scarce, expensive, and prone to cross-threading. It should be pretty simple to set up my valve seat and guide machine with the air-float work table to do an accurate job of opening up the plug holes to the bigger threads, as long as I don't hit the water jacket in the process of enlarging the holes. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Help me remember: do 1948 and older 216 and 235 have 10 mm spark plugs? I should know this. Thanks. Yes: the spark plug diameter changed from 10mm to 14mm in 1949 model year. The start/top of a "model year" is not a specified date. | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I think that 10mm plugs were just a war time thing . I know the early 216 , thru to '40 have 14mm plugs . | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks for causing me to look this up, Dusty
1929-1932 non-metric (7/8" x 18 thread) 1932 18 mm 1933-1940 14mm 1941-1948 10 mm 1949- 14mm | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Thanks Tim. Thanks all. There is so much misinformation on the internet. I’ve probably spread some of it myself. The first motor vehicle I owned was a 40 Chevy car my grandpa gave me when I was a teen. I took the engine partially apart. It had flat top pistons, 14 mm plugs and a tall side cover. I always believed it was a 216. I guess it was a 49-53.
Professional Novice
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Looking at the chart 1940 was 14mm..... the 10mm started in 1941 if i am reading the chart right. (I wasn't around then so I can't tell from personal knowledge). | | | | | Joined: Jan 2020 Posts: 620 'Bolter | | 'Bolter Joined: Jan 2020 Posts: 620 | Personally I would stay with original plug size. I have never had problems with the 3/8ths (10 mm), plugs, granted they may cost more but I have so many AC's in stock. Doc.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2015 Posts: 11,067 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,067 | Specialty, Marine? I guess Stovebolts are Special.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I think 1940 was the last year 216s had domed pistons. That’s why I think mine (all those years ago) had a 49-53 engine. I guess a 40 block could have been fitted with flat top pistons and a later head...
Sorry guys, too much time on my hands. Thanks for all responses.
Professional Novice
