4 members (Charles in CA, Otto Skorzeny, 2 invisible), 107 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#138266 05/30/2007 6:28 AM
V
Junior Member
Junior Member
V Offline
I'm having a real bad lean problem with the 5200 holley I just put on my truck. It runs great on the primary but, backfires through the intake when the secondary opens. I just went through the dizzy new points, condenser, cap, rotor, plugs. The vacum and dwell are good, the vacum advance is working, and the timing I've ran from 4btc all the way to 12btc. I've done quarter turns on the air/fuel screw from a turn all the out. The sweet spot is about 3-3 1/2 turns. Still the same so I think it's got to be the jets. Anyone got any insight or suggestions??? Right now it's running a .60 primary and .50 secondary. Oh and yeah I even rechecked the float on the brand new rebuild I got from Langdon's. You never know ;-)
#138267 05/30/2007 9:42 AM
1 Offline
vindog420,
Does it have a power valve ? The little rubber diaphragm has a tendency to tear, It is especially vulnerable to engine backfires. When the engine sneezes back through the intake manifold, it generally will kill the power valve.
It's just a thought...
420 ? Hmmm...Lol
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#138268 05/30/2007 9:31 PM
Riding in the Passing Lane
Seems like the secondary jets are usually larger then the primary.
1972 Chevy c10 Cheyenne Super
#138269 05/31/2007 5:56 AM
V
Junior Member
Junior Member
V Offline
OooOooOoo I gots it figured out. The fuel pump went south. Got a new one under $20. Stovebolts are fuggin' great. Thanx for all ya' alls help.
ViNDoG
#138270 05/31/2007 1:28 PM
I've run both the single Holley and the dual Carter/Webers on my 235....discovered that the mechanical pump supplied a little too MUCH pressure. Added an inexpensive adjustable regulator and inline gauge.(AutoZone) I keep my fuel pressure at 3-3.5 pounds at the carb and have had no problems with starving or flooding, or dumping fuel into the intake after I shut down the engine.
Dave
Webshot "Tips and tricks" and "Shoebox" Photo Albums
EXPERIENCE is the best teacher...but it gives the test first...and the lesson afterwards.
"What this generation tolerates...the next will embrace"
#138271 06/06/2007 1:52 AM
vindog,
If your 3+1/2 out your idle jet is too small. The idle jet is under the brass screw on the choke side (primary side) on the Holley/Weber 32/36. If you are running a 235 chevy with some mild cam and headers you'll need a 65,70 or 75. The idle circuit takes you all the way up til about 2000 rpm. Put in a 65, set the idle down low without stalling, and readjust so it is not more than 1+1/2 out. If its out more than 1+1/2 put the 70 or the 75 til you have it adjusted out not more than 1+1/2 out with a good vac 19+. Thats your first step before you start changing main jets, air or emulsion tubes. Put on a good holley regulator that you can adjust down to not more than 3+1/2 lbs, chevy pumps can put out as much as 7 lbs, way too much for the sensitive weber needle and seat.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
#138272 06/06/2007 10:29 PM
52 PU...some very useful information! And the more I think about it, many of the Holley/Weber, Carter/Weber problems that folks might experience, in addition to getting rid of vacuum leaks, are related to excessive fuel pressure. I used a regulator and gauge when I added the single H/W to my old engine and also on my new engine with the dual Carter/Webers. I've experienced no problems what-so-ever, all the way from idle up through the secondaries.
This may be the key to getting good performance right out of the box.
Dave
