2 members (Shaffer's1950, 1 invisible),
36
Mod | | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 21 Apprentice | | Apprentice Joined: Apr 2007 Posts: 21 | what year(s) nova can i scavenge a front clip from to put under my 51 3600 chassis ?
thanks in advance
raf | | | | | Joined: Mar 2007 Posts: 3,374 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,374 | I have heard most people use the older models, 68-69. They have rear steer design, the draw back is they are hard to find now days and they don't come with disk brakes. You may want to find something newer as parts will be earier to locate. Remember Pontiac, Olds and Buick share many of the same componets. A good start would be to do a search on this subject and see what is pulled up.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | try a early 70's 2 wheel drive truck front clip ? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If I recall correctly, the '68-'75 Nova used the rear steer design, then went to front steer in '76. I wouldn't think parts would be too difficult, as many swap with Camaro, Chevelle/Malibu, and even S-10. I do knw one of the other reasons for the earlier subframe is that it's a little narrower than the later ones. They fit better under an AD truck.
Bill Burmeister | | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | I used a 74 nova under a 53 I built years ago. And yes up to 75 had rear steer. | | | | | Joined: Oct 2006 Posts: 843 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 843 | Mine's a 72Nova,rear steer with disc brakes.The drawback to rear steer is the colum has to cant over slightly to line up,only room for one universal. | | | | | Joined: Mar 2005 Posts: 311 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 311 | 1974 was the last year for rear steer.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | forget the nova clip and invest in a mustang II for the time you will have the truck it is a good investment. a little pricey up front but for the long haul a good bet. every thing new and serviceable and some come as a bolt on unit. IMHO. i have a pacer ifs on mine but it was put on 20 years ago and the mustang was not in wide use at the time. i have put two power racks on it and if i have to do it again i will change to the mustangII. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | Camaro's work fine too. But just remember with any subframe to make sure that you wont run into tire clearance issues.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | the front steer novas were from 75-79. it may be wide for your truck though, and it is the same as the camaro sub.
i hear monte carlo (g-body?) subs are narrower and may work better
2003 ford lightning 1959 chevy 36
| | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | I have a Mustang II in my 54 and in my 40. Thats the only way to go IMHO... | | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | I'm with WE b OLD. I think the MII is the way to go. I have 1 of each. My 53 has a Camaro front steer, my 48 has a MII. I haven't driven the 48, but it's clean simple and the width is perfect if you want a low truck. I drive my 53 and it has a front steer Camaro/Nova. It rides great, but the set up is more complex, it's too wide for a low truck, and harder to put the bumper on. I used 5" wheels and really still can't get it as low as I want without the tire hitting the fender in turns. Do not use a rear steer. I've seen the set up and it doesn't work right. You'll have to put the column at a weird angle and it looks like sh*t. Before everyone tells me how wrong I am, let me say, I've done all 3 and this is my opinion.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | MII's are fine, I've been using them since they made the 1600 OHV Pinto. Used the actual setup from the Pinto and MII and made our own strut rod eliminator. What is not good with them is they have limited travel so you have to use springs that will keep the shock from over extension or bottoming out. This is fine on street cruisers but a problem on a truck that will see off road or heavy hauling service. Don't get channel minded when building your ride and sometimes think outside the box. Here is a picture of a rear steer setup that leaves the steering column in the exact factory position and has been trouble free for nearly 30 years. A double roller chain will wind a 3/4 steering shaft up into a pretzel and never feel the strain. Scroll down to the blue 51 GMC--second picture. http://s32.photobucket.com/albums/d41/coilover/
Evan
