1 members (klhansen),
147
0
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2018 Posts: 140 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 140 | I need some advice on rebuilding a sm420 4 speed. I think the pilot bearing may be worn and causing a little “lurching” when driving downhill without using the accelerator. I was told I should rebuild the transmission. I haven’t rebuilt a transmission before and was wondering how hard it will be. Is there anything I should be aware of before/ during the build? What kit should I be looking at? | | | | | Joined: May 2017 Posts: 100 'Bolter | | 'Bolter Joined: May 2017 Posts: 100 | Very easy transmission to rebuild, get a manual or look on line for free, tells you all you need to know. The bad news some parts are really tough to find. Bearing kit easy synco"s are a bear to find, gears are a tough to find . Input shafts can be found, Also gaskets and seals can be found. Have fun .Pilot bushing can be found easy. Spare parts look for complete transmissions on the bay. That's where I found most of my parts.
https://www.ebay.com/itm/Transmission-Rebuild-Overhaul-Kit-GM-Chevy-SM420-Rockcrawler-BK108/201172915184?epid=686087659&hash=item2ed6d713f0:g:6esAAOSwQItUGN7X
!956 Gmc Napco 4x4 Factory line built .
| | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 |
Professional Novice
| | | | | Joined: Feb 2012 Posts: 36 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 36 | Tim Tygarts is no longer in business. Apparently now doing business as "Chevs of the 40's" | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am unsure why you need to rebuild the transmission for a pilot bearing issue? Is it just because you will pull it out to replace the pilot? SM420’s last for years with just normal care. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Truth of the matter is sm420s last fot years with "no" care. They last forever with "normal care".  | | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | I wouldn't waste my time rebuilding a SM420. There are so many good used ones around and most of them sell for practically nothing. That is the reason parts are difficult to find. We ran quite a few SM420s back in the '50s and 60's. The only one I remember failing was a PTO leaked so much oil that it ran dry. We went out and bought a used one like everyone else did back then. I'm not sure what you mean by a little lurching down hill and whatever it is probably wouldn't be fixed by a complete transmission rebuild. What kind of experience does the guy that suggested going through the transmission have? | | | | | Joined: Sep 2011 Posts: 1,459 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,459 | [quote=Snowman51]I need some advice on rebuilding a sm420 4 speed. I think the pilot bearing may be worn and causing a little “lurching” when driving downhill without using the accelerator. /quote]
So going downhill, foot off the accelerator, is the clutch engaged or released?
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2018 Posts: 140 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 140 | Clutch is engaged. Vibration/noise seems to stop if I put in the clutch. | | | | | Joined: Mar 2018 Posts: 140 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 140 | | | | | | Joined: Feb 2004 Posts: 29,859 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,859 | I'd taker a very close look at the universal joints and the rear end pinion bearings before digging into the transmission. Coasting with the clutch disengaged takes the load off the entire drivetrain, including the rear end and driveshaft. An SM-420 is about as bulletproof a transmission as there has ever been. The rock crawler crowd loves 'em because of that super-low ratio granny gear, so the prices are getting a little steep on good condition used transmissions. Jerry
| | | | | Joined: Mar 2018 Posts: 140 'Bolter | | 'Bolter Joined: Mar 2018 Posts: 140 | Thanks for the advice. It has new universal joints and drive shaft. Sounds like I need to check the rear end first. It’s an open driveshaft 3:90 from a ‘57 HO32. The PO put it in and it looks like some farmer welding for the attachment. Could the problem be pinion angle at the rear end? | | |
