Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Dakota Bob, Wally / Montana), 98 guests, and 3 robots.
Topics128,275
Posts1,058,439
Members48,490
#138187 05/22/2007 5:22 AM
I'm not to familiar with shaved door handles.
Are bear claw latches necessary?
Where do you mount the popper?
It is all electrical?
Colin
#138188 05/22/2007 6:31 AM
Colin, you don't have to use bear claw latches if yours latches are in good shape.
The popper's are mounted inside the door with a cable or wire to the door latch.
And yes they are electrical..
A lot of shops sell the door kits but here are two i found www.autoloc.com and www.electric-life.com
Hope this helps
Wayne
Working on a 1952 Chevy Suburban
#138189 05/22/2007 10:55 PM
Thanks Wayne,
Lots of info on the net of putting them in, but hardly any mention of the little things (the obvious maybe?).
Are power locks a necessity then? Seems like they would have to be in order to not defeat the purpose.
Colin
#138190 05/22/2007 11:16 PM
Usually you would disable the locking mechanism. Personally I'd stay away from autoloc's and look into Spal's if you want to use solenoids. Reason being I've seen a number of autoloc's rusted out after 2 years or so.
As an alternative look into actuators to open the locks instead of solenoids. They seem to work a lot smoother and tend to be less bulky.
But that's just my opinion after having installed both types in a number of different type applications.
#138191 05/23/2007 4:02 AM
Apprentice
Apprentice
colin you can contact my brother Todd he lives in edmonton he can help you with all your questions. He has a car in his shop right now that he has shaved the handels on, maybe you can give him a visit and see what your up against. contact me and I will give you his number.
Greg.
it's not how much time you spend on it, it's how you spend your time with it
