| | | Forums66 Topics128,274 Posts1,058,436 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | I'm not to familiar with shaved door handles. Are bear claw latches necessary? Where do you mount the popper? It is all electrical?
Colin | | | | | Joined: May 2007 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 34 | Colin, you don't have to use bear claw latches if yours latches are in good shape. The popper's are mounted inside the door with a cable or wire to the door latch. And yes they are electrical.. A lot of shops sell the door kits but here are two i found www.autoloc.com and www.electric-life.com Hope this helps Wayne | | | | | Joined: Apr 2001 Posts: 439 Shop Shark | | Shop Shark Joined: Apr 2001 Posts: 439 | Thanks Wayne,
Lots of info on the net of putting them in, but hardly any mention of the little things (the obvious maybe?).
Are power locks a necessity then? Seems like they would have to be in order to not defeat the purpose.
Colin | | | | | Joined: Jun 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 191 | Usually you would disable the locking mechanism. Personally I'd stay away from autoloc's and look into Spal's if you want to use solenoids. Reason being I've seen a number of autoloc's rusted out after 2 years or so.
As an alternative look into actuators to open the locks instead of solenoids. They seem to work a lot smoother and tend to be less bulky.
But that's just my opinion after having installed both types in a number of different type applications. | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | colin you can contact my brother Todd he lives in edmonton he can help you with all your questions. He has a car in his shop right now that he has shaved the handels on, maybe you can give him a visit and see what your up against. contact me and I will give you his number. Greg.
it's not how much time you spend on it, it's how you spend your time with it
