8 members (msmall, 68ironhead, Shardean, DannyW, Eisenholtz, 3800GUY, Shade Baby, cmayna), 41 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#1380145 10/09/2020 7:28 PM
Driving along and then lost all lights. Driving lights, spot light, fog lights and brake lights all inoperable. Checked headlight switch (good), checked fuses (good), check bulbs (good). Starts up fine, stereo works air ride system works just no lights.
AJsdad #1380149 10/09/2020 7:37 PM
Please post what year make model your vehicle is.. and does it have a stock wiring harness.
Another quality post.
Real Trucks Rattle
AJsdad #1380151 10/09/2020 7:56 PM
Check your dimmer switch. Unplug the connector and clean the contacts and plug it back in.
Justhorsenround - I actually replaced the dimmer switch and cleaned all the contacts. It has been converted from a 6 to 12V and all wiring looks good.
AJsdad #1381769 10/22/2020 7:17 AM
Latest update. I climbed under, over, and in-between to check all wiring, fittings, and fuses and still no lights. At this point, I think I'm going to order a new light switch and try that. I already replaced the dimmer switch.
AJsdad #1381771 10/22/2020 7:25 AM
If you lost brake lights, those don't go thru the headlight switch or the dimmer switch. The circuit up to the brake light switch should be hot all the time. Work your way upstream from the headlight switch with a test light. Check at each terminal and when you get the test light to light up, your problem is between that terminal and the previous one you tested.
klhansen #1382341 10/26/2020 11:21 PM
KLHansen Thanks for offering up some tips. Forgive my ignorance with anything electrical, but could you explain further about working upstream from the headlight switch
AJsdad #1382363 10/27/2020 1:08 AM
If you're losing power, start checking for voltage at the battery, then at the starter, then at the ammeter, (working your way downstream) and when you stop getting voltage, back up one terminal and check the wire between there and the last one you checked.
When I said working upstream, you could go that way too, checking voltage at the item that isn't working, headlights in your case, and back toward the battery.
