1 members (Eisenholtz), 59 guests, and 3 robots.
Topics128,022
Posts1,055,377
Members48,422
In my chevy shop manual it tells about the application of "Goodyear Pliabond #3" to the mating surfaces of the flywheel and crankshaft flange prior to bolting them together. I have never seen any of this "Goodyear Pliabond #3" in my local autoparts stores. What would be the modern equivalent to "Goodyear Pliabond #3"?
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
I don't think I can shed must light, but Pliobond(sp) is a contact cement.
I installed my flywheel to crank dry, then used Red Loctite on the threads of the 6 flywheel bolts. You can use the 12 point SBC flywheel bolts if you need new ones. Don't forget the lock plates if you've got a good set, torque bolts to 60 FT/Lbs.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
