| | | Forums66 Topics128,096 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2020 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2020 Posts: 25 | I am searching for the correct tank, straps and sending unit for my 1948 suburban. Are they the same as the 1948 3100 truck? Please help. Or a link to pics of the right one.
Also the paint code for the interior brown please. Thanks
Mark | | | | | Joined: May 2015 Posts: 11,101 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,101 | According to Jim Carter's website, the 47-48 1/2 ton pickups, 47-55 Panels and Suburbans use the same tank. Jim Carter's item #MEG149 Don't know the paint code, but it's somewhere here on the site. Or someone knows.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | I used the reproduction tank from Jim Carters and it is a quality item. It fit my original straps perfectly. I recommend it. Start with a nice new tank to eliminate the worries of Debri in your fuel system.
As far as the gas tank straps you will have to find a set used, I have not seen them reproduction. Posting an parts wanted ad here and or a EBay search should yield results.
The interior paint code is a tough one because most paint systems change code numbers and before you know the code I give here that worked on my suburban three years might now come up purple in some other paint system. Shoot me a PM and I can try to help you with it, but look at my photo album first and see if you like my interior color.
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | |
