| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13812 12/18/2003 5:05 AM | Joined: Sep 2003 Posts: 343 Member | | Member Joined: Sep 2003 Posts: 343 | In my chevy shop manual it tells about the application of "Goodyear Pliabond #3" to the mating surfaces of the flywheel and crankshaft flange prior to bolting them together. I have never seen any of this "Goodyear Pliabond #3" in my local autoparts stores. What would be the modern equivalent to "Goodyear Pliabond #3"?
1954 GMC 1/2-ton Longbed 1971 Pontiac LeMans Sport
#13813 12/18/2003 8:41 PM | Joined: Jul 2002 Posts: 188 Member | | Member Joined: Jul 2002 Posts: 188 | I don't think I can shed must light, but Pliobond(sp) is a contact cement. | | |
#13814 12/18/2003 9:21 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I installed my flywheel to crank dry, then used Red Loctite on the threads of the 6 flywheel bolts. You can use the 12 point SBC flywheel bolts if you need new ones. Don't forget the lock plates if you've got a good set, torque bolts to 60 FT/Lbs.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
