0 members (), 93 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1380905 10/15/2020 10:51 PM
I understand that GMCs are a bit quirky and haver a few differences compared to the Chevys, but was it common for AD GMC trucks to have both the top and drivers side cowl vent? I don't believe I have ever seen it on a Chevy, but I saw two different Jimmys in the same day that have both drivers side vent as well as on top of the cowl. Any info on this?
My 54 3100 has cowlvent And on the right kick panel it had the delux heater vented outt side.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
I’m a little confused by some of the wording, as I’m not totally familiar with terms, but my ‘57 Chevy 3200 has passenger and driver side floor vents that get fresh air fed in through the cowl between hood and windshield.
1957 Chevy 3200
Daily Driver
PS, A/C, Tilt column, Rebuilt 350, Rebuilt TH350, Reupholstered Bench Seat, sound proof/insulated, LED headlights/taillights/backup lights/interior courtesy lights.
Follow in the DITY
I believe all AD's had the top cowl vent under the windshield. But the driver's side cowl vent only went thru '50 models.
The earlier Advance Design (AD trucks from 47-54 had cowl vents to let fresh air in. From 47-50 this vent was on the drivers side just in front of the door. 51-54 they moved that vent to the top of the cowl just in front of the windshield, behind the hood. I just happened to see two GMC trucks that have both! I didn't think that even existed. I have never seen it before much less two trucks that have both vents in the same day.
Maybe that is it. I am probably just confused. for some reason I thought there was always a single vent, either side or top mount. For some reason I thought the 40s models only had the side vent
This should explain it. 47-50 both vents, 51 saw the introduction of ventipane (wing windows), GM then eliminated the side vent.
https://www.flickr.com/photos/advance-design_parts_co/albums/72157649468726416
https://www.flickr.com/photos/advance-design_parts_co/12315230903/in/album-72157640522200463/
62401
Man, are you guys in luck! We have a Tech Tip in our very own Stovebolt.com Tech Tip Library that explains all this.
Tech Tip on AD differences
But to sum up, ALL AD truck cabs have the top cowl vent (in front of the windshield). All '47 through '50 have the driver's side side cowl vent. In '51, its function was taken over by the vent windows (in the door).
As far as I know, the GMC cabs follow the same evolution.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
After reading what John suggested I wonder if on my 54 I could have mounted an earlier fuel tank under the bed. I have an after market under the rear of the truck and dependeniing how much fuels is in it changes the ride. But having it closer to the center it might have been better.
2017 Buick Encore
See more pix
Yes, my '50 has both the top cowl vent and driver's side vent in front of the door.
Craig
Thanks John, I'm always learning something. Ed
My 49 gmc 150 has the cowl vent and the drivers flip out vent. The fins are stamped into the pass side for the fresh air heater but its got the blank out plate on it since I run the small recirc heater.
Two vents eeeek
Right hand drive? Or a really old custom job?
That might actually be 3 vents, but can't see the top of the cowl. wink
I think its A Holden. Aussie or so africa
Rt hand drive
62401
Dads50 -- wow, that's REALLY interesting! It just goes to show you ... It would be interesting to hear from our So. Africa or Aussie guys to see if that's something they've seen also.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Makes sense that they'd put an operable side vent on the right side of a RHD truck. It'd be a PITA to have to reach all the way across the cab to the left side to open the vent there. Now, how they'd install a fresh air heater, is the question. Any idea if those were made mirror image to the American ones, so they'd fit on the left side?
Originally Posted by Brad Allen
Verrry Interesting. wink
A new person joined from Aus, check out his truck RS cowl vent.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/topic/199624.html
