3 members (Phak1, kades51, TUTS 59), 241 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
#1381006 10/16/2020 1:51 PM
PA OUTLAW
PA OUTLAW
Hello all does anyone have a list of the bolts nuts washers ! Size and type the hardware it takes to assemble the bed on 1954 chevy 3100 short bed except the woodenbed floor !!! Thank you in advanced
Easiest way is to check with Mar-K (or other vendors). They sell a bolt kit that takes care of the floor, and may also sell the others. IIRC, the front panel to bedside bolts and front panel to cross-sill bolts are 1/4-20 (probably 3/4" or 1/2" long with a flat washer and lock washer under the nut. I believe the rear corners are also 1/4-20, but they may be 5/16. You can check the drilled hole sizes and use the largest that will fit thru the hole. They are all hex head bolts.
