6 members (Otto Skorzeny, klhansen, sron48, Hotrod Lincoln, Shade Baby, Phak1), 86 guests, and 4 robots.
Topics128,041
Posts1,055,483
Members48,424
#1380848 10/15/2020 3:05 PM
What is the best way to remove the horn button in the center of the steering wheel? Will a small screwdriver work? I don't want to bend or damage anything. Thanks!
bucktruck #1380853 10/15/2020 3:37 PM
On my 49 3100 the button can be carefully pried off. Patience is a virtue here.
Ed
bucktruck #1380954 10/16/2020 3:44 AM
Corrosion can make them stubborn. Be careful not to mar the steering wheel when you pry on horn button. It is pretty soft. A wide blade screwdriver is your best bet.
bucktruck #1381108 10/17/2020 1:44 AM
I use a screw driver but do not allow the screw driver to rest anywhere against the steering wheel itself. I instead allow my finger to be the item the screwdriver rests against. Yes, if not, the screwdriver will put a dent into the edge of the steering wheel horn cap opening.
Craig
