| | | Forums66 Topics128,012 Posts1,055,320 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | What is the best way to remove the horn button in the center of the steering wheel? Will a small screwdriver work? I don't want to bend or damage anything. Thanks! | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | On my 49 3100 the button can be carefully pried off. Patience is a virtue here.
Ed
| | | | | Joined: Mar 2010 Posts: 10,270 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,270 | Corrosion can make them stubborn. Be careful not to mar the steering wheel when you pry on horn button. It is pretty soft. A wide blade screwdriver is your best bet.
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I use a screw driver but do not allow the screw driver to rest anywhere against the steering wheel itself. I instead allow my finger to be the item the screwdriver rests against. Yes, if not, the screwdriver will put a dent into the edge of the steering wheel horn cap opening.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
