| | | Forums66 Topics128,128 Posts1,056,661 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 19 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 19 | Question please- I am getting ready to reassemble the panels after painting. Are there some sort of gaskets that should be placed between parts (fender/cab) to prevent squeaks, etc please? Thank you in advance? | | | | | Joined: Mar 2014 Posts: 4,504 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,504 | Well, there were long gaskets between the fender and the inner fender and the body and inner fender (splash gaskets) and there were shorter gaskets where the inner fender mounted onto the firewall, but nothing between the fender and the cab. And on the back fenders, there were gaskets between the running board and the fender that looked sort of like an S. Some people in the 50s and 60s added fender welting, but you're on your own with that scheme. It isn't anything I'd do, because I've seen too many trucks suffer rust because those things invariably harbor moisture. If you've painted the cab and fender correctly (that is to say you've painted the inner surfaces of where the fender will mount and the inner mounting surface of the fender itself), you ought to be just fine.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Jul 2020 Posts: 19 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 19 | | | |
