| | | Forums66 Topics128,049 Posts1,055,651 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | Doing the front brakes on the 46 1/2 ton. We are keeping them original. I am taking the drums to O'Reilly's to get them turned. Do I have to remove the hubs to get them turned? If I do do I have to pound out the studs? I finally removed the races from the old outer bearings and replacing them. I bought a brake kit from Chevs of the 40's. Any advice would be greatly appreciated. Thank You in advance. | | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | The hub can be left on. I'd say preferred. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Hog Wild, check with O'Reilly's to see if they would like the hubs, without bearings or grease with the drums, or if they can turn the drums without the hubs? | | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | Is there really any reason to remove the hub from the drum? | | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | o'reilly did my rears but said he couldnt do the fronts. had a bearing and brake shop do it and they did it intact with races still installed. removed the seals though.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Jun 2020 Posts: 60 'Bolter | | 'Bolter Joined: Jun 2020 Posts: 60 | o'reilly did my rears but said he couldnt do the fronts. had a bearing and brake shop do it and they did it intact with races still installed. removed the seals though. Awesome thank you 37 GC | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Anyone who can't figure out how to turn a drum with the hub attached has no business whatsoever working on my brakes. That's like betting your life on drawing to an inside straight! Jerry
| | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | I'll repeat, preferred. I'd rather have a drum spin concentric to the bearings it will spend its life spinning on, than possibly lining up centered through the axle hole or stud holes on some brake lathe. | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | Make are to thoroughly clean all of the old grease out of the hubs before you reassemble to avoid running bits of metal in your new bearings.
| | | | | Joined: Oct 2005 Posts: 4,251 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,251 | Plus, the guy turning them would appreciate not having grease all over his brake lathe. | | | | | Joined: Feb 2004 Posts: 29,767 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,767 | Hub/drum combinations need to be mounted on the drum lathe spindle with "radius cones" that use the bearing races as centering points. That also applies to disc brake rotors with integral bearing races. If the guy running the machine doesn't know that, RUN do not walk away! Jerry
