2 members (lumbersawyer, klhansen), 75 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1366039 06/23/2020 3:23 AM
What’s everyone doing for carpet? I have a 54 3100 with a SM420 4-on the floor (so trans cover has a hump). Trying to keep fairly color coordinated with brown.
GMJager #1366219 06/24/2020 12:54 PM
Molded carpet is available from all the typical vendors.
I like this website... seems like they have the most options:
https://www.stockinteriors.com/item...1954&FilterCoverage=&FilterBody=
They also have a molded rubber floor mat.
'59 Chevy Suburban, NAPCO
GMJager #1366222 06/24/2020 1:16 PM
PS. Good luck finding one with a high hump... seems like a tough search right now.
this is the only one i could find:
https://www.tuckersparts.com/Carpet-Kit-CC-5071.html?cat=1252
GMJager #1366264 06/24/2020 6:06 PM
You did not mention it but before put carpet in, put down sound and heat pads in. I took mine to an upholstery shop.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
GMJager #1366677 06/27/2020 3:49 PM
Depending on what you are doing/using truck for..
I put sound barrier down...then the molded "rubber" mat.
My truck is used on our ranch..So...I can "hose" it out if needed...
Put carpet in and it would be impossible for me.
But that is just my 2 cents.
1950 Chevy 3100
GMJager #1370402 07/23/2020 11:53 PM
I have to use rubber flooring also I work at a rock crusher very dirty.
GMJager #1379812 10/07/2020 2:00 AM
Can you 'mold' your own carpet? Like with a steamer or something?
I've had no luck finding anything for my '49 3600 with the 4 speed. The tall tunnel really kills any pre-made options.
GMJager #1397851 02/18/2021 10:35 PM
I ordered a carpet from the Tucker Parts link that GMJager posted. The only color on offer (on the website) for "high hump" floor shifter installations ('49 3600 SM420) came in blue, which worked out fine for me.
When the carpet arrived it looked good, had insulation on the back, good binding, but no cutout for the floor shifter. I called Tucker Parts to see if they maybe sent the wrong one, but no, they don't cut out for the shifter, in case someone has modified their truck to a column shifter. They also said that there's practically no difference between 'high' and 'low' hump and that the rubber mat they sell is the same for both. Lastly, they said you can have any color in the high hump version, you just have to call it in as they haven't gotten around to programming it into the website.
PapaDisco #1397856 02/18/2021 11:09 PM
AD Addict & Tinkerer
Thats strange as I’ve never seen a 4-speed column shifter in a AD truck! In the case a SM-318 was installed one would think that you would also install the 3-speed transmission cover.
Phil
Project Journals
Stovebolt Gallery Forum
Phak1 #1397968 02/19/2021 6:21 PM
I would love a 4 on the tree! But alas, no such thing. The carpet guys were referring to folks who delete their 4 spd in favor of an automatic.
GMJager #1397982 02/19/2021 7:48 PM
It kinda makes sense but I would still get the three speed tranny cover as it has no hole to patch.
Phil
Project Journals
Moderated by  ndkid275, Phak1
