7 members (Slick Willy, Lostbuthaulinass, Otto Skorzeny, homer52, Gib70, BC59, 1 invisible),
115
Mod | | | Forums66 Topics128,134 Posts1,056,410 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2020 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 36 | I have a 1952 Chevy truck with this engine rattle noise. The truck has been sitting a long time and just got the plugs and wires replaced. This noise is concerning. Anyone know what it is? Chevy 216 Engine rattle noise | | | | | Joined: Mar 2000 Posts: 1,181 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,181 | That's an odd one there. It's not rhythmic, which you would expect if it were some sort of valve train or piston problem. The motor sounds good. I think the first thing I would do is take the valve cover off and see if there's anything loose under there. It could be something metallic just bouncing around in there. It sounds very light, like a small piece of metal. | | | | | Joined: Jul 2020 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2020 Posts: 36 | Thank you for the reply. The noise ended up being a bent push rod. It would slowly rotate and the bent part would make contact with the inspection cover. | | | | | Joined: Feb 2004 Posts: 29,815 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,815 | That's a BIG red flag warning about a sticking valve. If you started a sleeping engine without doing a lot of preliminary work, including using a clean gas tank, you've probably got more problems on the way. Varnish and gum from stale gas gets dissolved when fresh gas is added to an old tank, and it ends up in the valve guides. Broken rocker arms and bent valves from contact with the piston tops are other possibilities. Jerry
| | | | | Joined: Dec 2018 Posts: 2,450 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 2,450 | Grn 52 chevy Soak your guides with MMO,put in upper cylinder lube,take your time it''ll get over it !! | | |
