5 members (2-Ton, Otto Skorzeny, TUTS 59, KEVINSKI, Fannin), 155 guests, and 2 robots.
Topics128,084
Posts1,056,085
Members48,434
I have a 1952 Chevy truck with this engine rattle noise. The truck has been sitting a long time and just got the plugs and wires replaced. This noise is concerning. Anyone know what it is?
Chevy 216 Engine rattle noise
1952 Chevrolet 3100 "Green"
The re-store in the Project Journal
Red dot, center of chest ...
That's an odd one there. It's not rhythmic, which you would expect if it were some sort of valve train or piston problem. The motor sounds good. I think the first thing I would do is take the valve cover off and see if there's anything loose under there. It could be something metallic just bouncing around in there. It sounds very light, like a small piece of metal.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Thank you for the reply. The noise ended up being a bent push rod. It would slowly rotate and the bent part would make contact with the inspection cover.
That's a BIG red flag warning about a sticking valve. If you started a sleeping engine without doing a lot of preliminary work, including using a clean gas tank, you've probably got more problems on the way. Varnish and gum from stale gas gets dissolved when fresh gas is added to an old tank, and it ends up in the valve guides. Broken rocker arms and bent valves from contact with the piston tops are other possibilities.
Grn 52 chevy Soak your guides with MMO,put in upper cylinder lube,take your time it''ll get over it !!
