| | | Forums66 Topics128,010 Posts1,055,299 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Do any of you folks know where I could get a squirrel cage for 1950 Chevy 1 1/2 ton I did find some online but it doesn’t specify standard or deluxe heater I’m guessing mine is a standard, the rectangle one.
1950 4400
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | What is wrong with yours?
Ed
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Joe, Type this in your browser. A lot of listings will pop up. I doubt there were different heaters for the size of truck. The 2 T will be the same as the 1/2 T. The Standard and Delux probable used the same fan motor. 1950 chevy truck heater motor squirrel cage Harold
Harold Is a restoration ever finished? | | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Squirrel cage broke My heater is rectangular shape has 3 doors on front that lifts up It has Supreme on the front
1950 4400
| | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | It’s rectangular shape and 3 doors on front
1950 4400
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | The reason for asking what is wrong with yours is to keep you from rushing around when it could be fixed. A squirrel cage is not a high tech component. "It's broke" tells us nothing. What is wrong with it? Many of us like to fix stuff. If you don't want to fix it, that's fine. If you have determined it is unfixable, then OK. I agree with Harold. No reason for Chevy to have a different motor or cage just for STD and Deluxe....and many years should work. Just compare the dimensions of cage and it's shaft hole size. Here you go..... CLICKThis is plastic. This May work for a metal one. Dimensions are very close to the first linked cage.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2019 Posts: 116 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 116 | Squirrel cage broke means it’s broke, it is in 2 pieces . The ones I have found say for Deluxe heater and this leads me to believe it may be different from the other ones.
1950 4400
