Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1379202 10/02/2020 1:00 AM
Do any of you folks know where I could get a squirrel cage for 1950 Chevy 1 1/2 ton I did find some online but it doesn’t specify standard or deluxe heater
I’m guessing mine is a standard, the rectangle one.
1950 4400
Joe Alan #1379203 10/02/2020 1:15 AM
Crusing in the Passing Lane
What is wrong with yours?
Ed
Joe Alan #1379215 10/02/2020 2:22 AM
A picture here would really help there are two standard heaters for 1950 neither of which is really square?
https://www.flickr.com/photos/advance-design_parts_co/8129448404/in/album-72157631868452754/
If you have this one which is correct for 47-48 deluxe and super deluxe plaques exist, you see them with and without the add-on defroster.
https://www.flickr.com/photos/advance-design_parts_co/49141664128/in/album-72157631868452754/
This heater could have lingered for years on a dealer shelf or been retrofitted from another truck. If it is not one of these three you are in Canada or have an aftermarket.
Joe Alan #1379222 10/02/2020 3:32 AM
Joe,
Type this in your browser. A lot of listings will pop up. I doubt there were different heaters for the size of truck. The 2 T will be the same as the 1/2 T. The Standard and Delux probable used the same fan motor.
1950 chevy truck heater motor squirrel cage
Harold
Harold
EdPruss #1379295 10/02/2020 7:41 PM
Squirrel cage broke
My heater is rectangular shape has 3 doors on front that lifts up
It has Supreme on the front
1950 4400
Brad Allen #1379296 10/02/2020 7:43 PM
It’s rectangular shape and 3 doors on front
1950 4400
Joe Alan #1379306 10/02/2020 10:03 PM
Sir Searchalot
Sir Searchalot
The reason for asking what is wrong with yours is to keep you from rushing around when it could be fixed. A squirrel cage is not a high tech component. "It's broke" tells us nothing. What is wrong with it? Many of us like to fix stuff. If you don't want to fix it, that's fine. If you have determined it is unfixable, then OK.
I agree with Harold. No reason for Chevy to have a different motor or cage just for STD and Deluxe....and many years should work. Just compare the dimensions of cage and it's shaft hole size. Here you go..... CLICK
This is plastic.
This May work for a metal one. Dimensions are very close to the first linked cage.
bartamos #1379882 10/07/2020 6:25 PM
Squirrel cage broke means it’s broke, it is in 2 pieces . The ones I have found say for Deluxe heater and this leads me to believe it may be different from the other ones.
1950 4400
