7 members (TexasFarmTruck, Otto Skorzeny, MOTOXFAMILY, Phak1, kurbside bolter, 2 invisible), 157 guests, and 3 robots.
Topics128,268
Posts1,058,378
Members48,485
#1379071 09/30/2020 11:54 PM
Thanks everyone.
Turns out after a little investigation I’ve got a 3600 with 3100 emblems
Thanks again
George
Last edited by Gchef; 10/01/2020 1:37 AM. Reason: Im an idiot. I did more research and found my answer
Gchef #1379078 10/01/2020 12:50 AM
The 3600 had an 87" long bed. 3100 bed is 78" inside. Maybe someone put a short bed on it. Just like they put 3100 emblems on the hood.
1952 Chevy Vehicle Information Kit
Gchef #1379085 10/01/2020 1:31 AM
Or put an 8 bolt rear end under it? Or put a 3100 body on an 3600 shortened frame? Any frame mods noticeable? Im sure some one will be able to give the frame dimensions and the difference between the two. Then at least you will know what frame you got. Vin number match? Look tampered? Good tranfered title?
klhansen #1379100 10/01/2020 2:39 AM
Thank you
Gchef #1379102 10/01/2020 3:02 AM
Wheelbase is in the link I attached.
3100 has 116" wheelbase. Rear axle is 39" behind the back of the cab.
3600 has 125" wheelbase. Rear axle is 48" behind back of cab.
Gchef #1379154 10/01/2020 6:07 PM
Hi George! Good to see another NJ here!
1951 Chevy 3100
"Project for my Wife" - Jigsaw Puzzle
1969 Camaro SS350 convertible
1969 Camaro 327 convertible
Moderated by  Dusty53
