| | | Forums66 Topics128,268 Posts1,058,378 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2020 Posts: 13 New Guy | | New Guy Joined: Sep 2020 Posts: 13 | Thanks everyone. Turns out after a little investigation I’ve got a 3600 with 3100 emblems
Thanks again George
Last edited by Gchef; 10/01/2020 1:37 AM. Reason: Im an idiot. I did more research and found my answer
| | | | | Joined: May 2015 Posts: 11,268 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,268 | The 3600 had an 87" long bed. 3100 bed is 78" inside. Maybe someone put a short bed on it. Just like they put 3100 emblems on the hood. 1952 Chevy Vehicle Information Kit
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Or put an 8 bolt rear end under it? Or put a 3100 body on an 3600 shortened frame? Any frame mods noticeable? Im sure some one will be able to give the frame dimensions and the difference between the two. Then at least you will know what frame you got. Vin number match? Look tampered? Good tranfered title? | | | | | Joined: Sep 2020 Posts: 13 New Guy | | New Guy Joined: Sep 2020 Posts: 13 | | | | | | Joined: May 2015 Posts: 11,268 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,268 | Wheelbase is in the link I attached. 3100 has 116" wheelbase. Rear axle is 39" behind the back of the cab. 3600 has 125" wheelbase. Rear axle is 48" behind back of cab.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Apr 2002 Posts: 65 'Bolter | | 'Bolter Joined: Apr 2002 Posts: 65 | Hi George! Good to see another NJ here! 1951 Chevy 3100 "Project for my Wife" - Jigsaw Puzzle 1969 Camaro SS350 convertible 1969 Camaro 327 convertible
