14 members (Otto Skorzeny, Jims46, manymiles, MikeE, Southerntruck, joe apple, Hawkman, J Lucas, D B Cooper, Oldcaliforniakid, Stovebolt48, Bill Hanlon, 2 invisible),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,674 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | I am currently in the process of changing the rear motor mount crossmember on my 1951 1 ton for a 1954 1 ton crossmember so that I can mount a 292 and new style bell housing in my truck. When I put the 1954 crossmember in, it doesn’t sit flush on the bottom of the frame rail, it appears that the frame rail on my 1951 is wider than the 1954 frame. I was wondering if someone with a 1954 or 1955 first series 1 ton could measure the bottom width of the frame rail where the rear motor mount crossmember sits.
Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Frame dimensions are in the Vehicle Information Kits.Only available for Chevy trucks. GMC may be different, but I don't know.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | Thanks, I have checked that as well as the assembly manual and they don’t show the dimension that I am looking for.
Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: May 2015 Posts: 11,031 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,031 | Isn't it dimension "b" that you need from Tim's link? That's the same as the Vehicle Information Kits info. Those dimensions are the same for either '51 or '54.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | I seen that and the problem with dimension “B” is that this is the max sectional dimension, the dimension actually varies the length of the frame. For example I measured the rear of my frame and it measure 2.405”, I measured near where the rear motor mount is and it measures 2.75”, and I also measure the front which measures 2.36”. GM also changed their part number for the frame in 1954 as there was a change to the rear motor mount. So even though dimension “B” is the same for the 51 and 54 frame, the actual dimension where the motor mount sits could actually be different. Before I start removing material, I want to ensure that my measurements are correct.
Thanks Dave
1966 Chevrolet Caprice 2 Door Hardtop (396 Big Block) 1951 GMC 9434 5 Window (waiting on a 292 transplant) | | | | | Joined: Apr 2007 Posts: 3 Moderated | | Moderated Joined: Apr 2007 Posts: 3 | DID YOU GET THE DIMENSIONS YOU NEEDED? MY 1TN FRAME IS BARE ON STANDS. I CAN GET WHATEVER DIMENSION YOU WANT. SEND ME A PHOTO/SKETCH OF WHAT YOU NEED. | | | | | Joined: Sep 2008 Posts: 57 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 57 | Thanks for the offer. I ended up taking measurements from the crossmember, marking the frame and removing a little bit of material on each side until it fit. Thanks again.
Dave
