does anyone have a pic of there spring to hard bent hook where it attaches to the frame plate? second question on rear brake line does it go above the ebrake pivot bracket or thru the bracket
That second pic you posted is correct for the brake line routing. At least that's the way mine was. BTW, that bracket has nothing to do with the parking brake cross-shaft, it's a frame/crossmember bracket. You'll notice the cross-shaft doesn't even touch it.
Kevin 1951 Chevy 3100 work truck Follow this saga in Project Journal Photos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together.
thanks Brad, I guess the repo part is slightly different. I just placed it on one of the crossmember bolts but was trying to understand where it really should connect
