| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | I'm switching my '65 C-10 over from a manual transmission to an automatic. I'd like to switch the brake pedal over to an automatic pedal... any idea of what will work and does anyone have one?
Lee | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Auto's used the same pedal back then,,til about 71 or 72 IIRC. I would think a later pedal could be made to fit. Brian | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The pedal changed when they went to disk brakes. If yoou look at an automatic '71-'72 pedal, there's a small chrome medallion in the center that says "Disk Brakes". Manual trucks and the earlier trucks used the same pedal. I suppose that you could swap in a '71/2 pedal to your truck to get the look you want.
Bill Burmeister | | |
