1 members (lumbersawyer), 84 guests, and 1 robot.
Topics128,055
Posts1,055,782
#1378402 09/25/2020 3:07 AM
I located the serial number on my engine which I was told was a 1955 235 cu in. Is this correct and is it a 1st or 2nd series engine. I bounced around google and didn’t locate it. I attached a picture if I did it right. The serial number is “070I845 F55y” the fourth character is an i not a one
F55y
y (actually, it is a Y) = the series Type (size/model of truck)
F55Y
F = Flint, MI engine plant
55 = 1955 (first series, if it is a truck engine)
Second Series 1955 trucks would have had a year code of 255.
1955-1st series truck codes
1955 car engine codes
Maybe another member knows what the "trailing "y" ("Y") designates as a series Type?
Insomniac
Insomniac
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Thanks, Gord
I could not make out the "Y" on this page.
(Automatic - Powerglide)
That engine was originally in a car.
It has hydraulic lifters.
Wow, that’s a surprise to me. Is there anything additional I should know about the engine? It’s in a 1953 GMC. I appreciate the great info you guys have provided
How long have you had that engine in your GMC?
Have you (or a shop) ever adjusted the valves?
What adjustment technique did you/they use?
Chevrolet used the capital letter"eye" as number "one" in their serial numbers.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
