4 members (Hotrod Lincoln, baldeagle, Joe H, Bill Hanlon), 112 guests, and 4 robots.
Topics128,014
Posts1,055,333
Members48,419
#1378356 09/24/2020 8:18 PM
There is a good tech-tip about doing this. I tried to find the author in the member list without luck My questions were can I use the spacing block for the backing plate from the Huck system. Secondly do you have to do anything to the master cylinder.
Any answers will be appreciated.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
The tech tip says he used the Bendix spacer, but if the Huck spacers are the same thickness, you could drill out the mounting holes and use them. Not ever seeing Huck brakes, I'm guessing here.
Master cylinder should work as-is, assuming it's the same piston diameter.
Sedgewick #1378387 09/25/2020 12:55 AM
I think he had a full axle to pull parts from. All I have are the backing plates.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
The problem with the swap is the difference in size of the holes in the steering arms. They are smaller on trucks with Huck brakes. The Bendix use larger diameter steering arm bolts, so there is a problem with the backing plates having holes which are too big for the Huck bolts.
This leaves you with two choices. Drill the holes larger in the Huck steering arms, or welding the holes in the Bendix backing plate to a small diameter.
I wasn't comfortable with drilling the Huck steering arms, so I welded plate steel to the backing plates on the wheel side and drilled the holes to fit the Huck steering arm bolts.
Hope this helps. You kind of have to "be there" to visualize it clearly.
I would think it would be easier to enlarge holes (a larger drill will self center in the existing holes) than to weld and drill smaller holes (getting them centered where they need to be), but either way would work. Spacer blocks were mentioned, but I haven't dug into my brakes yet to see where they are.
It's only 1/16" bigger, I just drilled the holes , been near 20yrs now , daily use .
ODSS President
ODSS President
Did the same as Dusty, easy conversion, used the same Huck single MC.
~ Cosmo
1949 Chevy Half Ton
Sounds very doable. It is only a 1/16" difference in the steering arm holes. And I am happy to learn the original MC is good to use.
Thanks all.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
