5 members (rfs56trk, Gib70, Lightholder's Dad, Gray_Ghost, 1 invisible), 134 guests, and 1 robot.
Topics128,080
Posts1,056,060
Members48,433
#1378273 09/24/2020 1:05 AM
I've been dismantling the '46 and making a list of needed parts. There's a 2" x 8" x 8' support beam between the frame and the flatbed frame that is cut were it goes over the notch in the frame. Does anyone know what kind of wood is best to use for this? I think I'm going to use Siberian Larch wood for the bed but I can only find it in 5 1/2" wide stock. I've located treated yellow pine, which I think is what they used in the original bed. Would that be strong enough for this application?
Also anyone know where I can get the insulation that goes around the inside track of the window glass?
It also has this crazy longhorn vinyl on the seat, but I doubt it was original, see photo.
Joe
1946 Chevy 3/4 Ton Flatbed
Tearing her down
Story in the DITY Gallery
More images
Use White Oak for the 2x8 supporting the bed. I would use yellow Pine or White Oak for the bed surface. I would not use treated lumber, but if you do be sure to use the correct hardware. Treated lumber has chemicals in it that are corrosive to steel and zinc plated fasteners.
Steve
Steve
1946 1/2 ton
If you're talking about the rubber around the outside of the window, Jim Carter lists it, but is on backorder right now.
Window seal
Hi Steve,
Thanks for the info. Should the White Oak be treated or finished with any sort of preservative? I was going to use Siberian Larch for the bed. From what I'm reading it's pretty impervious to pretty much anything. I'll have to check on it's reaction to the hardware.
Joe
Tearing her down
More images
Hey Kevin,
I meant the material on the inside of the window channels.
Tearing her down
More images
Originally Posted by JoeR
Hey Kevin,
Jim Carter lists that too, also on backorder. frown
1934-1946 Window Channel Chevrolet and GMC Pickup Truck Item # WI201
Morning Kevin,
Looks like I'll be dealing with Mr. Carter a lot, and waiting a lot. lol. I've found some of what I need at the Chevy's of the 40s too. After going over the truck, now that I have it back, I'm pretty sure I'm going to take it down to the frame and do a complete restoration. Removing all the body panels will make the 235 installation a lot easier. I've got to remove the flatbed to replace the wood support anyway so I might as well take everything else off and do it right. That way I can replace all the nuts and bolts, body mounts and other rubber parts as needed. I was originally thinking about replacing the suspension but since I probably won't be driving it more that 20 miles in any direction at this point I may just get rebuild kits for the knee shocks and see how it goes. There are only a couple small dents in the one fender that should hammer out easily and a little dent in the cab near the back window. I'm not sure how my Homeowner's Association feels about me painting the body parts in the driveway but as the old saying goes it's easier to get forgiveness than permission. :-)
Joe
Tearing her down
More images
